While bleeding my clutch I noticed fluid dripping from the bell housing. I took off the slave cylinder and noticed the rod was missing. Does anyone have any tricks to get it off with out lowering the trans?
Slave Cylinder rod stuck in trans
Tags: None
Its easy dont over think it. you may have to lower the rear of the trassmission. You can probably get a magnet and get the rod out. one the slave cylinders out.84 318I Delphin RIP
87 325IS delphin 24v Sold
89 325 Alpineweiss -
Get a magnet that's not too powerful and you should be able to fish it out. It's a pain in the ass, but doable.2006 GMC Sierra 2500HD 4WD LBZ/Allison
2002 BMW M3 Alpinweiß/Black
1999 323i GTS2 Alpinweiß
1995 M3 Dakargelb/Black - S50B32/S6S420G/3.91
1990 325is Brilliantrot/Tan
1989 M3 Alpinweiß/Black
sigpicComment
Damn this happened to me on the the day I was trying to make bimmerfest. I ended up pulling the tranny, good luck!Comment
Drill a hole in the bottom and then plug it when you are done.Past Car : E30 S50 6 Speed 5 Lug 3.73
Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
___________________________________________
BNB Designs
Engine Swaps, Fabrication, Innovation, General Repair
Richmond CA
Julian 848-248-8029
I ended up removing the rod. It was a bitch, but not as bad as I thought. For sure not something that I want to do again. I used a cloths hanger, with a name tag magnet which I had from working retail, duck taped together and it worked great.
My friend tells me that I could reuse the slave and rod, that seems sketchy to me. What do you guys think. I dont mind buying a new one, I dont want to deal with this again, but I dont want to be wastful, if mine is still good.Comment
Having taken one apart, I don't see anything wrong with that.
Unless, of course, it looks crappy in there.
Edit: You need to take it apart to reinstall the rod properly.2006 GMC Sierra 2500HD 4WD LBZ/Allison
sigpicComment
