Could somebody make an accurate calculation with scheme how much is the corner difference between those cams?
					m50 non-vanos hot cam timing
Subscribed.
Much difference in idle?Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Originally posted by der affefirst try a finger or 2, you need to have them suck on it first and get it nice and wet to help it slip in.
if she goes for that, astroglide up your pole, have her lay on her stomach and slip it in slowly and bury it to your balls and leave it there until she relaxes. once she is used to it slam that ass like a screen door.Comment
I calculated the lobe centers and durations
Intake opens: 19 BTDC (9.5 degrees on the cam)
Intake closes: 41 ABDC (20.5 degrees on the cam)
Duration 19+41+180 = 240 degrees
Lobe Center ((41-19)/2+90)= 101 degrees ATDC
Exhaust opens: 35 BBDC (17.5 degrees on the cam)
Exhaust closes:13 ATDC (6.5 degrees on the cam)
Duration 35+13+180 = 228 degrees
Lobe Center (35-13)/2+90= 101 degrees BTDC
Timing for nonvanos intakecams
Exhaust opens: 41 BBDC (20.5 degrees on the cam)
Exhaust closes: 19 ATDC (9.5 degrees on the cam)
Duration 41+19+180 =240 degrees
Lobe Center (41-19)/2+90= 101 degrees BTDCComment
exhaust 50,5degree on cam before top dead center
intake 50,degree on cam after top dead center
So the difference is exact 101 degrees. Intake cam should be turned 101degrees clockwise and then lobes will be in same place.
I“ll measure the back end of the camshaft for timing jig and make one nextweek.
thanks for help.Comment
Wow, I forgot about this thread. I have my dual intake cams installed and running on megasqurit. All seems good but I am not wondering if the timing is as good as it can be. Does anyone else have any experience with this?1988 325 auto-x car
1989 325ix winter car
1991 525i summer carComment
After doing some more reading, I am satisfied that my timing is good. I am now thinking of having my intake cam reground to s50 intake specs1988 325 auto-x car
Interested in this as well since I just installed NV motor in my e30. Would I need any other tuning or just properly adjusted cams?
Thanks"i love vee tek, its a wonderful sound when you driving right by it"
If you bought anything from me, please leave a feedback here: http://www.r3vlimited.com/board/show...ghlight=drulleComment
