M50 Diagnostic port
  • SamE30e
    • Sep 2007
    • 4319
    M50 Diagnostic port
    I searched, but no luck
    I hooked one of those cables to my diagnostic port, and with no luck it didn't work. Does this cable need power to it to work? Also is it possible to pull a tach signal from it on the "TD" pin.
    Thanks
    Sam
    1985 325e 2.8 Turbo VEMS
  • matt
    • 3732
    Hard to tell what the cable needs given that you haven't even told us what cable it is. :)
    I am not aware of anything out there that is capable of pulling a tach signal from the diag port, but I believe it is present there.
    • SamE30e
      • Sep 2007
      • 4319
      It was my neighbours USB plug for the OBD-1 BMW diagnostic port. I got a Zeitronix wideband and data logger and I need a tach signal for the input.
      • m3boost
        • Oct 2005
        • 110
        I think it's pin 1
        88 e30/s50 gt35r turbo m3
        96 gt4094r turbo m3
        452 rwhp, 455 rwtq at 14 psi 91 octane
        681 rwhp, 684 rwtq at 25 psi E65
        • Dominic49
          • Feb 2007
          • 1373
          i can get a tach signal with the gt1 through the diag on my s50 rofl....
          • SamE30e
            • Sep 2007
            • 4319
            omgrofl!
