Locking the S52 @ TDC
  • m3manic55
    • Nov 2008
    • 24
    I have an s52 that I recently swapped and I will be putting an MLS Head Gasket on it soon and I have been reading up on how to R&R the Head Gasket. Pelican's Atricle call for a TDC locking tool.
    See Fig.4
    http://www.pelicanparts.com/BMW/tech...ead-Gasket.htm
    I was wondering though, that since I have the Getrag 260 and M20 single mass flywheel will this tool work or will I have to hold the motor at TDC some other way?
  • matt
    • 3731
    You will need some other method.
    • m3manic55
      • Nov 2008
      • 24
      crap.... any ideas anyone?
      • E30FTW
        • Jan 2008
        • 76
        Set the crank to TDC by the marks on the crank/timing case. Remove the crank hub pulley. Use a longer M8 bolt in the top most hub bolt hole. Tighten it finger tight until it hits the timing chain case. Add 1/4 turn.
        Crank is now locked.
        • surebimmer
          • Jan 2004
          • 978
          Here is a picture of the marks on the front crank/timing case marks.
          • m3manic55
            • Nov 2008
            • 24
            awesome. i will def do this.
            The cam locks are necessary though I am assuiming? I cant see ay way around that...
            • lifeiskaos
              • 1709
              Originally posted by e30ftw
              set the crank to tdc by the marks on the crank/timing case. Remove the crank hub pulley. Use a longer m8 bolt in the top most hub bolt hole. Tighten it finger tight until it hits the timing chain case. Add 1/4 turn.
              +1
              • surebimmer
                • Jan 2004
                • 978
                The cam locks are necessary though I am assuming? I cant see way way around that...
                Yes cam locks are needed. If you have the cam's locked in place and those timing cover marks line up your good to go.
                • m3manic55
                  • Nov 2008
                  • 24
                  damn... those locks are expensive....
                  • Mossman
                    • Apr 2006
                    • 1961
                    Ask your regional forum on bimmerforums if anybody has a set you could borrow. If you're new/not on there offer to pay up front and bring a case of beer when you return them and get your money back. I'm sure somebody semi-local has a set
