S52 intake on M50
  • Fusion
    • Nov 2009
    • 3659
    S52 intake on M50
    A local guy is selling parts from a blown S52B32 '97 M3, he still has the complete intake with throttle bodies.
    I'm just wondering if its possible to mount on an M50 with any interesting results, or is it just a really bad idea?
    Can the cams from the S52 be used in the M50, if so buy both?
  • lifeiskaos
    • 1709
    s52's only have one throttle body
    • mongule
      • Dec 2004
      • 177
      Maybe he means the traction control part.
      Anyways, don't do this. Totally counter productive. Everyone with an OBD2 car switches to the m50 manifold for a reason. This is like gettign a chip for your car that does less power then stock.
      I'm not sure on the cams, depends if you have non vanos or vanos m50.
      87 OBDII 328is
      • lifeiskaos
        • 1709
        Ah, yeah true. OBD2 intakes are much more restrictive due to emissions. You want to keep the OBD1.
        If you have a vanos m50, grab the cams and trays.
        • Fusion
          • Nov 2009
          • 3659
          Ah, I have NV M50. And also realized the OBD2s have the smaller intake holes.
          Thought the S52 also had the nice TB six-pack like the S50.
          • decay
            • 5637
            Fusion is in europe... aren't all the e36 m3's ITB'd over there?
            past:
            1989 325is (learner shitbox)
            1986 325e (turbo dorito)
            1991 318ic (5-lug ITB)
            1985 323i baur
            current:
            • Wh33lhop
              • 11705
              No S52 has 6 throttle bodies. Perhaps he is thinking of the S50B32.
              Either way, the throttle bodies aren't exactly bolt-on to an M50. The M5x and non-US S50 are completely different motors.
              paint sucks
              • Fusion
                • Nov 2009
                • 3659
                Aka late model Euro.
                I think this should be S52B32. Main difference is that it has Dual Vanos, the S50 being single.
                I simply have no idea what would happen if the TBs and intake were mounted to an M50.
                • nrubenstein
                  • 3148
                  There was never, ever an S52 in Europe. It was the S50B32. And nothing translates to your M50.
                  Well, actually, Alpina used the S52 for a LONG time.
                  2002 BMW M3 Alpinweiß/Black
                  1999 323i GTS2 Alpinweiß
                  1995 M3 Dakargelb/Black
                  - S50B32/S6S420G/3.91
                  1990 325is Brilliantrot/Tan
                  1989 M3 Alpinweiß/Black
                  • Fusion
                    • Nov 2009
                    • 3659
                    My info says otherwise.
                    BMW Code ... BMW Code ... Size (litres) ... Cyl ... Valves per Cyl ... Power (PS@rpm) Torque (Nm@rpm) ... Manufactured ... Bore x Stroke (mm) ... Timing ... Weight (kg) ... motor management ... camshaft, valve, intake and other control ... Used in
                    S52 - S52B32 ... 3152ccm ... 6 ... 4 ... 321 @ 7400 ... 351 @ 3250 ... 96 -> 2000 ... 86.4x91 ... Chain ... 152 ... Bosch DME ... Bi-VANOS ... E36 M3 (Euro)
                    These engines are notoriously known for the Dual Vanos going bad at around 90K miles, the engine then has a diesel sound to it.
                    • ethrty
                      • Nov 2009
                      • 342
                      yep no S52 outside of the US. they jumped straight to the S54 in euro spec. Do want S50B32 :D
                      • Fusion
                        • Nov 2009
                        • 3659
                        Ok, my information comes from a shithole, sorry guys.
                        Its a S50B32.
                        • Iain
                          • Oct 2005
                          • 2815
                          Your info is wrong. Get a pic of the engine, mate.
                          The Euro M3 engines are totally different to US engines - there was a thread in this section recently with some great info on that.
                          I will be investigating how to fit S50B30/32 M3 ITBs to my Euro-spec M52 stroker (alu block from a Euro E36 328i) but it isn't going to be a direct bolt-on. You'll also have brake booster problems (ie: it won't fit)
                          Pork Hunt Motorsport
                          eBay is like the summit racing catalog for today's special Olympics crowd
                          • Fusion
                            • Nov 2009
                            • 3659
                            So the intake ports and bolts have a different pattern eh?
                            And I have M50B25 euro spec.
                            • Fusion
                              • Nov 2009
                              • 3659
                              Ok, found a guy in Germany who has the ITBs on an M50B28nv
                              Asking for more info now.
