What did I miss!!?? OBDI S52.
  • MR E30 325is
    • Dec 2008
    • 3300
    Alright, I am tired of this. My 1991 318is with an OBDI S52 will not start.
    It cranks over and over and over, but it wont fire.
    I have no spark (confirmed by pulling the plug, grounding it and cranking the car.)
    I had no fuel. But for some reason after putting the covers on, and cleaning up the engine bay, I could hear the fuel pump priming when I turned the key on. Though it still wouldnt start up.
    The engine is from a 98 M3. the wiring harness and DME is from a 95 M3.
    I am 1000% positive that the plugs are all connected correctly, as I personally pulled the harness from the M3, and I labeled every wire as I removed it.
    The DME is a silver label 413, but i bought an EWS chip from another member, though I am not sure if its what I need. the chip says
    Belleville motor we
    P/N 4131 3001.
    The wiring was done by a guy who has done plenty of swaps before, and I personally checked the wiring, and everything checks out.
    I am running out of options here. Should I try to locate a red label 413 to see if thats what i need??
    It seems like the EWS is still being enabled by the symptoms. it cranks over fine, but I have no spark, and no fuel.
    What do I do!!? I want to tear up the streets in my car asap!
    My previous build (currently E30-less)
    http://www.r3vlimited.com/board/showthread.php?t=170390
    A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
  • MR E30 325is
    • Dec 2008
    • 3300
    Adding a little E30 S52 pron to help with the thinking process!!
    • Dominic49
      • Feb 2007
      • 1373
      crank sensor ok? fuel pump lines crossed?
      • MR E30 325is
        • Dec 2008
        • 3300
        crank sensor is connected and properly seated in the little housing on the front of the engine. Does it need to be held in by the screw in order for it to properly work??
        Its held on by a zip tie, cause I dont have the proper allen screw to hold it in.
        The fuel should be going into the rear part of the fuel rail, by the FPR right?? Cause thats how its set up right now.
        • FredK
          • 14761
          I don't think the Bonneville Motor Works PN 4131-3001 chip deletes EWS. I believe it is just for Euro HFM.
          The equivalent part number for an EWS delete chip would be 4131-3401.
          http://www.turnermotorsport.com/page...ation_2008.pdf
          • MR E30 325is
            • Dec 2008
            • 3300
            Well that makes a lot of sense.
            I will look into finding a red label 413, or I will purchase the appropriate chip
            • 7pilot
              • 475
              "The fuel should be going into the rear part of the fuel rail, by the FPR right?? Cause thats how its set up right now."
              no.
              m
              • Dominic49
                • Feb 2007
                • 1373
                fuel exits at the pressure regulator
                • e30s50dan
                  • Nov 2008
                  • 2076
                  I would find a RED label ecu !!
                  NASA
                  BMWCCA member
                  PCA member 25yrs
                  1991 318IS slick top
                  1997 M3 sedan
                  2001 325CI DD
                  “whoever turns the wheel the least, wins"
                  • MR E30 325is
                    • Dec 2008
                    • 3300
                    Alright, I purchased a red label 413 dme. Still wont fire up, but the fuel lines are backwards.
                    I gotta swap the fuel lines around tomorrow.
                    Its ok to use the S52 spark plug packs right?? even though they are 1.8k??
                    Also, would the coolant temp sensor keep the car from starting? (I didnt tap the head, I simply spliced the wires and connected them together, following the guide in the OBDII to OBDI conversion write up)
                    • Adrian_Visser
                      • Jun 2006
                      • 2823
                      Swap the fuel lines. The coolant temp sender for the gauge isn't going to read right but the DME sensor will work.
                      '89 Alpine S52 with goodies
                      • MR E30 325is
                        • Dec 2008
                        • 3300
                        I swapped the fuel lines at 11 at night...............
                        AND SHE FIRED UP!!!!!! Oh its awesome, idles right at 600, and revs so so sweet!!
                        Two complaints though.
                        1) engine is making a crazy ticking noise, rpm dependent, and it sounds a lot louder by the drivers door than it does on the drivers side of the engine right by the fender.
                        2) white smoke is coming out of the exhaust. enough to notice at idle, and a lot with some gas.
                        I didnt run it long enough to let it warm up to see if the noise or smoke diminishes, but does anyone have any suggestions on what could be causing these two things??
                        • MR E30 325is
                          • Dec 2008
                          • 3300
                          How am I supposed to see if the engine is running too hot? What do other people do to get the gauge to work??
                          • gregslow318i
                            • Sep 2007
                            • 1918
                            tap the head and put the right sensor in it....
                            did you put oil in it? did some put oil in to the cylinder for storage?
                            looking for a e30m50 swap harness adapter pm me $150 shipped
                            email nitroman12@gmail.com
                            • MR E30 325is
                              • Dec 2008
                              • 3300
                              Didnt want to tap the head.
                              The oil is nice and full, fresh filter and everything.
                              I doubt oil was put into the cylinders, the engine was only out of a car for 3 weeks.
