Idle control valve
  • manuel325i
    • Jun 2004
    • 80
    Idle control valve
    I have an s52 obd 1 swap, and I think my icv is acting up. My question is are all e36 icv regardless of obd1 and obd2 the same? I've heard two things that 1. you have to get a icv from an obd1 and 2. BMW used the same ICV for all vanos e36 motors. I could check and just take the intake manifold off but then I'd have to put it back together to go to the store and buy another icv then take the manifold off again to replace it.
  • FredK
    • 14761
    It appears as though the ICV cross references between OBD-I and OBD-II engines.
    PN 13411744713
    • Unearth078
      • May 2008
      • 2623
      supposebly even the e30 icv works.
      Originally posted by Lof8
      4 doors allow you to transport more whores.
      therefore, their value is much greater.
      Down to: 89 aw2 332i/4/5 , 70 Sahara 2002
      • sushipower
        • Aug 2005
        • 156
        My S52 OBD 2 ICV is working on my OBD 1 conversion. So yes, you can run them on both.
        • Adrian_Visser
          • Jun 2006
          • 2823
          Really?
          '89 Alpine S52 with goodies
          • MattM
            • Apr 2009
            • 931
            Really?
            ive have seen M50 ICV's on M20's.. harder to tell the other way around.
            Full Build Thread Here
            • manuel325i
              • Jun 2004
              • 80
              Sweet thanks for the info fellas.
              • Unearth078
                • May 2008
                • 2623
                Originally posted by Adrian_Visser
                Really?
                i don't know first hand, but id be willing to give it a shot once i get my s52 sorted.
                i don't see why not tho. same connector and purpose. size is a bit different but that's all i see.
