DOHC Radiator options
I did the "double bleed" procedure I wrote about a few weeks ago and it worked damn well. Finally satisified, temps are exactly how I wanted them.
First bleed (front end slightly downhill, inside heater on full speed and full hot air) - Getting the engine warm took me a lot longer than if I was just driving the car. I don't really like the idea of revving at 2500 and just holding it there so I revved up and down between 1000-3000, massaged the upper radiator hose, and let it idle for a while before revving again. Filled coolant when needed. Pretty much each rev to 3000 meant bubbles in the exp. tank. The temperature was at 1/3 for a long time but all of a sudden it jumped to 3/4. That's when I popped the cap on and turned the engine off and just left the car like that for about three hours, when I was satisified with the engine being "cold".
Second bleed (got the front end up slightly on car ramps, heating on full) - topped up coolant, repeated the whole first process. This time it heated up faster, some more bubbles came up and when the temp rested at 1/2 I put the cap back, turned the engine off. I've ben driving in hot weather a tad under the 1/2 mark, traffic means hlafway + fan speed low. I've used fan speed high but it wasn't necessary, it barely creeps over 1/2.
I have the late model 325 "bubble" expansion tank, not sure what radiator, 80° tstat and switch.Comment
You don't have to use any specific expansion tank, anything that will fit works just fine. Jegs sells many that will work for around $50. Or you could just use a pice of PVC pipe, fittings and glue. It is just a canister/tank that needs to beable to handle the pressure of the cooling system and hold a quart or three of water.
Canton makes custom aluminum tanks for around $100 a pop, but you might find something in their catalog that will fit a bit cheaper.
Well i have never had any problems with my M42 rad. I have driven the car on long trips and in hot weather. Oh I am also running the factory fan clutch and a supercharger.
