Is the 328is zf the same as the m3 zf tranny?
  • 89325iturbo
    • Mar 2004
    • 723
    Basically having an m52 with the tranny and driveshaft it can all be bolted in using the stock e30 cross member right?
  • RoadHazard
    • Sep 2007
    • 163
    Yes trans are the same in both cars but not the drive shafts. If I remember correctly they have different number of bolts on the rear side.
    I remember someone could not use the M3 drive shaft he acquired but I could be wrong.
    90 E30 S50B30
    http://www.fquick.com/roadhazard/
    • flyboyx
      • 8371
      the 95 and maybe early 96 m3 had a 6 bolt flange where it bolts to the diff. the trannys are identical.
      Gigitty Gigitty!!!!
      • gregslow318i
        • Sep 2007
        • 1918
        iirc build date before 06/96 had 6 bolt diff flanges, everything after had 4 bolt
        looking for a e30m50 swap harness adapter pm me $150 shipped
        email nitroman12@gmail.com
        • dinanm3atl
          • Feb 2007
          • 7305
          328iS and M3(Late Model) have the same trans. Only the early M3s had the 6 bolt flange. So 97-99 328iS/M3 with ZF trans all have 4 bolt diff flange.
          • Mossman
            • Apr 2006
            • 1961
            Minor difference, but didn't 95 m3's have ZF310's and 96-99 M3 have ZF320's? Same from outside just a little bit more stout? I seem to recall the 328's having 310's along with some late e34's but maybe someone knows for sure
            • FredK
              • 14764
              Yeah, 95 M3s had ZF310s, as did the non-Vanos E34. Same length and everything, not sure on the internals. 328s had 320s.
