The tach and cluster coolant temp sensor has no been hooked up yet, but everything is there for the ECU.
Car started up immediately when I had the manifolds open, but shut it off immediately so the pipes wouldn't be too hot to remove for final welding.
Now the the exhaust is on and tried to start the car, smelled like fuel out the exhaust, so I think "OK rich, misfire will cause rich" pulled one of the coils out and low-and-behold the well was full of water.
Got everything dried out, car starts and kinda idles, almost surges. Then if I hit the pedal a little, it bogs then revs a little, then bogs, then revs higher.
In dire need of assistance.
Thanks,
Thanks,
