M54/M59 water temp wires
  • kariotahi
    • Sep 2007
    • 8
    Hi, I'm doing a M54B30 into an E30 swap, using a M50 non vanos loom, I'm told the single sensor on the M54 head with 4 wires can be fed to the 2 separate plugs on the M50 loom. Is this right, and which wires are joined to which. The M54 has grey/brown, brown/yellow, brown/red, and brown/violet. The M50 has brown, brown/violet on one, and brown, brown/red on the other. Any help appreciated, thanks.
  • Farbin Kaiber
    Lil' Puppet
    • 29502
    lol, one post and you've been here almost as long as I.
    • kariotahi
      • Sep 2007
      • 8
      Mmmmm, Joined the E30 race series over here, and a couple of forums at the same time, but have just got into the M54 conversion, got some parts from Hovering guy to help, just need to sort out this wiring. Hope to do a write up at some point to help others. I'm doing a conversion removing the vanos completely and using a non vanos computer. Should have it running in a few weeks.
      • hoveringuy
        • Dec 2005
        • 2753
        I'm using VANOS, your rules don't allow it?
        I used both stock M50 water temp sensors, one fit in the standard head location, the cluster sender I needed to add into the radiator hose.
        • kariotahi
          • Sep 2007
          • 8
          Yes, our rules allow it, but I've worked on the premise that simplest is best. Have locked the cams but have plenty of adjustment in the intake side, and by using the early M50 loom and computer everything's plug and play. Have gone so far as to use the m50 rocker cover and have made a front cam cover as well.
          I've been told by a couple of engine builders to utilise the torque of the M54 and not try to rev it too high. Am putting a M3 6 speed behind it,
