/\/\ iii e30 s52
  • /\/\ III
    • Nov 2007
    • 80
    /\/\ iii e30 s52
    Ok, guys, not sure where to start, but I just got my S52...I need help on where to start. AT a minimum, I would like to get the engine started outside the motor...I already got most of the swap parts...will post pics soon.
  • Wh33lhop
    • 11705
    You'd like to get the engine started outside the motor?
    Well... good luck with that.
    paint sucks
    • evil_twin
      • Nov 2007
      • 2965
      It's possible. In HS, we built a crate for the motor, wired everything up, was able to start the motor and let it run open headers
      It's not practical to do it though.
      Paypal: vdang5@gmail.com
      Delta Auto Care
      2875-C Towerview Road
      Herndon, VA
      703.435.1375
      My Feedback Thread: Evil_Twin
      • RoadHazard
        • Sep 2007
        • 163
        I can see how it's done. It's doable. The tricky part will be fuel but it's not too bad.
        90 E30 S50B30
        http://www.fquick.com/roadhazard/
        • matt
          • 3732
          Doable but stupid. Just put it in a car.
          • MattM
            • Apr 2009
            • 931
            i frequently will run SBC's and BBC's out side of their applications(marine or auto) It is very easy to do on a carbureted engine, and with about 3 wires and a jerry can you can run one. These engines are a little tricker because you are going to need a fuel pump in the system. if you can get a working fuel pump system going, then its really only a case of touching wires to the battery to get the engine running.
            Full Build Thread Here
            • Van Westervelt
              • 9365
              Be careful, cus you just might accidentally ................. the whole motor.
              • george graves
                • 20003
                I could tell by the title there was going to be a little bit of 'tard in this thread.
                Originally posted by Matt-B
                • ACHTUNG
                  • May 2005
                  • 2397
                  Ha! so true.
                  1989 US E30 Cammed S52
                  Under Construction: 1983 Euro E28 Cammed LQ9/LS3 Heads/Jakeb E28 LSx Kit
                  • /\/\ III
                    • Nov 2007
                    • 80
                    the title offends you...ha..that is funny, what were you expecting, a finished product...like the quotes by the way,...
                      • 37833
                      Read this forum, then read it again... Then some more reading.
                      Install engine in to car. Drive car.
                      Grover Beach, California
                      BimmerHeads.com
                      • Wh33lhop
                        • 11705
                        Right, but what about starting the engine outside the motor?
                        paint sucks
                        • Fusion
                          • Nov 2009
                          • 3659
                          What came first? The motor inside the engine, or the engine inside the motor?
                          Mindfuck material.
                          • Wh33lhop
                            • 11705
                            The world may never know.
                            paint sucks
                            • RoadHazard
                              • Sep 2007
                              • 163
                              Didn't notice that LOL
                              90 E30 S50B30
