Chasing my tail with a DME code.
  • nrubenstein
    • 3148
    After clearing codes, I always get the Peake C8 "DME Control Unit" code on the SECOND startup.
    I've swapped DMEs, chips, etc, and it continues to do this to me. Where the hell do I go from here? I'm sick of looking at the check engine light.
    2002 BMW M3 Alpinweiß/Black
    1999 323i GTS2 Alpinweiß
    1995 M3 Dakargelb/Black
    - S50B32/S6S420G/3.91
    1990 325is Brilliantrot/Tan
    1989 M3 Alpinweiß/Black
  • flyboyx
    • 8371
    how does it run?
    Gigitty Gigitty!!!!
    • Schwarz325
      • Aug 2009
      • 487
      check your ecu relay?
      • nrubenstein
        • 3148
        It runs well.
        I suppose I'll swap the ecu relay again, but i've changed those before.
        • SiGmA_X
          • Mar 2006
          • 287
          EPROM, ECU, relay.. That is what I have been told. I had that or a similar code as well - Solution? Standalone :)
          :wgaf:
          PNW BMW Crew ///
          '93 325iS
          '99 528iT
          • matt
            • 3731
            Do you have a performance chip? That may be the 413's checksum code, which would indicate that the tuner forgot to correct the checksum on the chip before burning it. It shouldn't effect how the car runs at all.
            If you have a TRM chip, send it back to me and I'll fix it.
            • SiGmA_X
              • Mar 2006
              • 287
              This is 100% correct often. My personal issue just *happened* months after getting the correct checksum. One day I was driving along and it threw a CEL for DME memory supply IIRC.
              :wgaf:
              PNW BMW Crew ///
              '93 325iS
              '99 528iT
