Got a few questions regarding the flywheel/transmission bolts.
1.What bolts do I need If I am using a 323 flywheel on a s50?
are these it: 11-22-7-805-885
2. What is the torque spec for the bolts? 77ftlbs?
3. What transmission bolts am I going to need?
I'm using the 240 transmission from my 318is. Do I need all those bolts from in the diagram? Or do I use the bolts from the 318is trans?
Thanks. Any more info before I get this going would be appreciated. :)
