Puller fan wiring question
  • motorsports_3
    • Mar 2007
    • 1058
    I have been having an issue with my puller fan install. I used the spal diagram that keeps popping up in threads, and in the wiki site but everytime I have it connected it seems to ground out my stock aux fan up front and it stays on. I have to disconnect it to have it stop, so now I am running just the stock aux fan. Does anyone have an easier way to wire this up, or have an idea why it is causing the other fan to turn on. Thanks.
  • e30_325es
    • 1249
    Just get a painless wiring electric fan relay kit from jegs or summit. I did that and have no problems.
    • 87e30
      • Jul 2008
      • 5676
      I wired a cheap ebay fan into my foglight switch. Don't know if this idea helps you, I'm a complete wiring noob.
      I just hate everyone.
      No need for discretion.
      • motorsports_3
        • Mar 2007
        • 1058
        I dont really want to rely on a switched method. I want it to come on when the stock aux fan comes on. Does anyone know how to wire it up that way, or why mine keeps grounding off.
        • rosphill
          • Jun 2007
          • 187
          ^ That's what I've been wanting to know is how a 16" SPAL fan wires into the car, the diagrams aren't helping me much.
          Are the wires tied into the radiator temp switch and the fuse box?
          Also, it seems like most folks go for a pusher fan in front of the condenser, is that because a puller fan between radiator and engine is too tight of a fit?
          Originally Posted by Blunt
          I've done this so much I have a toenail on my dick.
          • motorsports_3
            • Mar 2007
            • 1058
            I have both the stock fan and a puller in between the rad and engine. It is a tight fit, but clears. I just cant seem to wire it right, lol.
            • jrdeamicis
              • Nov 2008
              • 956
              If you have a 3 prong connector for your fan, one wire is +12V and the other two are fan high and fan low.
              You will take the fan low wire and wire into a relay. pin 86 on the relay. Pin 85 will go to ground.
              Then take a fused 30a 12v from the car and put it to pin 30. Then take pin 87 to the fan 12V. Then ground from the fan.
              R & R for Fan High.
              There you go.
              For reference.
              Past Car : E30 S50 6 Speed 5 Lug 3.73
              Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
              ___________________________________________
              BNB Designs
              Engine Swaps, Fabrication, Innovation, General Repair
              Richmond CA
              Julian 848-248-8029
              • rosphill
                • Jun 2007
                • 187
                Ok thanks dude. :)
                This makes a lot more sense now that I've studied the diagrams some more.
                One thing I am still not sure about is when wiring in a fan,
                where is the connection point to tie into the ignition switch wiring?
                Thx
                • jrdeamicis
                  • Nov 2008
                  • 956
                  You should take the control off the stock fan switch location. Its already fused, switched and ready to go. As far as switched power goes for the fan, no switched power needed if the control side of the fan is switched with ignition....
                  BNB Designs
                  Richmond CA
                  Julian 848-248-8029
                  • motorsports_3
                    • Mar 2007
                    • 1058
                    So what you are saying will keep the fan on all the time the car is on, correct? I want it to run when the stock pusher turns on.
                    • jrdeamicis
                      • Nov 2008
                      • 956
                      The stock fan switch is a 3 prong connector. I gave directions above on how to wire an extra fan using the stock fan switch (piggy back or independent).
                      And what I was saying is that the fan power does not have to be switched since the fan switch already does the switching. (Done via the relay)
                      BNB Designs
                      Richmond CA
                      Julian 848-248-8029
                      • BustaRhymes325i
                        Gaping Anus OG
                        • Aug 2009
                        • 243
                        I too am having issues with my 16" pusher fan. It is an ebay special, and it has only 2 prongs on its connector. Can anyone comment on how to wire this setup?
                        • jrdeamicis
                          • Nov 2008
                          • 956
                          Its just one speed prob.
                          You can take your high and low speed wires and tie them together on the some control side of a relay and take the power side of that relay and use it to power one leg of that fan. Other leg to ground.
                          BNB Designs
                          Richmond CA
                          Julian 848-248-8029
                          • EricT
                            • 702
                            I just run my fan on the high speed circuit in the stock wiring.... of course I took the connector apart and flipped the plugs on the temp sensor on the rad so it comes on quicker. You can also get a lower temp rad switch from bav auto as well.
                            BUT THIS!!!!! http://www.r3vlimited.com/board/showthread.php?t=194272
                            • motorsports_3
                              • Mar 2007
                              • 1058
                              Where is the circuit located?
