OK, so, I have the AKG engine mounts and trans mounts, and needless to say, that communicates quite a lot of vibration at idle into the cabin. To complicate things, I'm running a mechanical fan, so the engine needs to not wander forward.
If I swap in softish (say, 320i) transmission mounts to cut down on the vibration/noise, will my fan be introduced to my radiator?
I've raised the idle to 1,000, which largely solves the problem, but I would rather have the freedom to run it lower (and not have the car vibrate on the occasions that my revs drop a bit lower).
