hey im almost done with my m50 swap into my e21, but it wont start and im gettin frustrated
. even tho i dont have an e30, the principles are the same. i've double checked everything about 5 times and it wont start. its not sparking and the injectors arent firing. it cranks fine. im almost positive i wired it up right. im using an e34 chasis plug that i wired into my fusebox. in theory, wont the engine run if the ecu and everythin has power like its supposed to even if something in the chasis plug wasnt hooked up right? i grounded everything, i hooked up all the hot wires, the ignition coils have power but wont spark its like the ecu wont send the signal to fire ya know. well then i thought it was the crank or cam sensor. i got a new crank sensor and it tested the same as my old one so thats not the problem. i basically diagnosed it to being maybe a bad ecu but im not sure.. What do u guys think? i need some input thanks
