Deleting PS on my m50, do I need a new belt?
  • skatingzooyork
    • 251
    I've read a ton of posts about people removing the PS on their cars including the m50 motors but I've never seen it be mentioned that you need a new belt.
    So I'm under the car today and I thought the pump was going to be on a separate belt but it's not, it has a serpentine belt for everything, so if I delete the pump, obviously I will need a shorter belt, right?
    Am I missing something?
    http://www.jfalesphotography.com
    91 318is m50nv - New toy/project
    95 540i - Wife's DD
  • MR E30 325is
    • Dec 2008
    • 3300
    You will need a shorter belt, but I do not know where to find one.
    My previous build (currently E30-less)
    http://www.r3vlimited.com/board/showthread.php?t=170390
    A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
    • skatingzooyork
      • 251
      Ok - I'm just surprised I hadn't read something about it before. Hopefully someone will have a part # for a shorter belt, if not I have no desire to run back/forth between the car and the parts store (closest store is 15min away) to find one that fits...
      95 540i - Wife's DD
      • Adrian_Visser
        • Jun 2006
        • 2823
        String and a tape measure man. The part number of the belt denotes the length. the width is 13/16ths
        '89 Alpine S52 with goodies
        • jrdeamicis
          • Nov 2008
          • 956
          I have a belt with the right # at home. Let me check later
          Past Car : E30 S50 6 Speed 5 Lug 3.73
          Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
          ___________________________________________
          BNB Designs
          Engine Swaps, Fabrication, Innovation, General Repair
          Richmond CA
          Julian 848-248-8029
          • matt
            • 3731
            6pk1420
            • EricT
              • 702
              I run a 6pk1390. It works also.
              BUT THIS!!!!! http://www.r3vlimited.com/board/showthread.php?t=194272
              • Dominic49
                • Feb 2007
                • 1373
                i use a 56.1inch belt
                • Dominic49
                  • Feb 2007
                  • 1373
                  the one eric mentioned works if you remove the idler pulley iirc
                  • lexx
                    • Mar 2008
                    • 62
                    Great info. I'm planning to do the same with my m50. A 6pk1420 belt will run the a/c correct?
                    • matt
                      • 3731
                      Nope. AC has its own belt.
                      • Dominic49
                        • Feb 2007
                        • 1373
                        ac is a seperate belt
                        • erik325i
                          • Jan 2005
                          • 3567
                          The AC belt is separate from the rest of the accessories.
                          • skatingzooyork
                            • 251
                            Thanks guys! Will definitely make the job a little easier tomorrow!
                            95 540i - Wife's DD
                            • chuck90m3
                              • 568
                              you can always just use 6PK X 1453 belt and install the PS pump delete that's on the newer cars like the Z4.
                              "A casual stroll through the lunatic asylum shows that faith alone does not prove anything."
                              Friedrich Nietzsche
