Some of you may have followed my build thread. Today I am trying to crank the car for the first time. Problem is that when I hook up the battery, the warning lights in the cluster light up. Key isn't in the ignition. The DME is not hooked up, I just want to crank the engine for now. (and not fry the 413 if i've done something stupid. I have moved my grounds but the same result occurs. I have hooked up my power as FredK has described in many threads. I also verified that all wired at the power lug on the passenger side are in fact red and that my grounds are brown. I do have an engine ground strap and have tried two different ones.
Turning the key does not turn on the fuel pump. There is some clicking when i turn it off but i can't tell if it is the evap valve or the Idle air control valve. <edit> it's the ABS pump. If i disconnect the C101, the abs light remains on.
For completeness, here is the pinout chart I created:
My search for this problem yielded an RNeedham thread that described the same issue but no resolution. Do any of you guys have any suggestions?
<sigh> so close yet so far....:(
