m50 swap will die and not start for a few hours.
  • ReSoP
    • Dec 2008
    • 148
    alright well Ive been driving around on my m50 swapped e30 for about a year and half and not a single problem until this.
    lately Ill be driving and everything is fine. go to pull up to a stop sign and the idle will surge until I've completely stopped and now sometimes when slowing down it will just die. and wont start back up until a few hours later usually sometimes it will start back up and ill have to rev it for a minute and itll be fine.
    I've replaced the fuel pump, fuel filter, fuel pump relay, dme relay. went out and sprayed brake cleaner on nearly every hose looking for a vacuum leak. Nothing. checked some ground wires which I made all of them new a year ago. I'm lost and dont want to keep dumping money into it and not getting anywhere.
  • hoveringuy
    • Dec 2005
    • 2744
    sticking injector?
    • samiam3356
      • Jul 2009
      • 1901
      This sounds so much like a bad fuel filter or pump but you said its been replaced. hmmmm maybe something fuel related then. Had this happen on a few cars and when I replaced the fuel filter on one and the pump on another everything was fine.
      Originally posted by Roysneon
      $5 shipped?
      Originally posted by MarkD
      You are a strange dude, I'n not answering any more posts from you.
      • ReSoP
        • Dec 2008
        • 148
        alright well I seafoamed it, cleaned the air filter........checked the ground wires. nothing still will randomly die and has to cool down befor starting again.???? I need to get this worked out. Its making me nervous driving it around
        • ReSoP
          • Dec 2008
          • 148
          the idle is surging more often now. And I put a load tester on it and my alternator is on the borderline of putting out enough. it also drops the more stuff on.
