Hi Guys,
I bought a used 92 E36, the previous owner claims the engine was swapped with a S52 from a 98 M3. I bought this car to swap the engine into a E30. Is there a way to verify for sure the engine/block is in fact a S52, not a M52 or M50? It does have the aluminum oil filter housing, 'M' valve cover and the late model intake manifold as well as the dash cluster has been swapped with a 'M' unit. Besides for that, the car is not running so I was hoping to find casting numbers to verify.
Thanks!
Thanks!
