o2 Relay/Oil Level Sensor
  • MSFIT
    • 81
    Got some wiring troubles; here's my current setup:
    Pinout for C101 off 84 325e
    01: Blue - Alternator
    02: Blue/Violet - Static Oil Level
    04: Brown/Violet - Coolant Temp Sensor
    06: Green/Yellow - ? (o2 Relay)
    07: Green/Violet - Fuel Pump Relay
    08: Black/Yellow - Starter
    10: Green - Ignition
    15: Blue/White - Dynamic Oil
    16: Brown/Green - Oil Pressure Switch
    17: White/Blue - Pin 7 of Diagnostic Connector
    Pinout for X20 off 95 325i
    04: Black/Blue - A/C Compressor Control
    05: Black/Grey - Normal Speed Relay
    06: Violet/Grey - Climate Control Module
    07: Black/Violet - Starter Immobilization Relay?
    08: Grey - CEL
    10: Blue/Yellow - ???
    11: Brown/Yellow - Engine Temp (x6071)
    12: Brown/Violet - Engine Coolant Temp
    13: Green/Violet - Fuel Pump Relay
    14: Black/White - Back of Speed - Vehicle Speed Output
    15: Black/Green - Wiper/Washer Module, Body Electronics Control Module (Underloader?)
    16: White/Yellow - Data Link (0670.5)
    17: White/Violet - Data Link to DME
    18: Black/Yellow - Starter
    19: White/Green - Service Reset
    20: Black - Engine Speed Input
    21: Green - Ignition
    22: Green/White - ???
    23: Brown/Green - Oil Pressure Switch
    24: White/Black - Fuel Consumption
    25: Blue - Alternator
    My current wiring:
    C101:X20
    01:25
    04:12
    06:22
    07:13
    08:18
    10:21
    16:23
    Concern's I have right now are:
    Oxygen Sensor Relay - What wire/pin on your x20 are you using?
    Oil Level (Dynamic/Static) - Same ^
  • MSFIT
    • 81
    Going off of this PDF
    Looks like the o2 relay is self contained in the harness, no wire through harness connector.
    Oil level sensor's are independent of the harness connector.
