No start after track day.
  • e304me
    • Feb 2006
    • 1374
    325 tanks will help fuel starvation as well, I want to do this swap too. What is the shipping price on that bitch?
    • Danny
      • 14216
      Dude swap the tank, fuck it. Do the subframe bushings while you're in there.
      • dude8383
        • Jan 2005
        • 10387
        Shipping was like $11...I shit you not.
        Subframe bushings are fresh, every suspension bit is fresh actually...it would just be a drop and replace affair :)
        The question is...are the tanks exactly the same? The 318is pump has a return and feed all in one. IIRC the 325i/is has a feed and then a return on the left side?
        • Danny
          • 14216
          Pretty sure they are the same. The 325 tank has another level sender on the drivers side. I think. Don't quote me though. Check realoem.
          • nmlss2006
            • 910
            AFAIK Danny is right - tanks are the same, fuel level system is not.
            • dude8383
              • Jan 2005
              • 10387
              Definitely has two different P/N's:
              325i - 16111180175 - http://www.realoem.com/bmw/showparts...39&hg=16&fg=05
              318i - 16111177983 - http://www.realoem.com/bmw/showparts...46&hg=16&fg=05
              • Danny
                • 14216
                You can see the different level senders on the 325 tank, not sure about fuel return however.
                • dude8383
                  • Jan 2005
                  • 10387
                  They are slightly different in terms of holding different capacities.
                  The 318i/is holds 55L/14.5 gal while the 325i/is holds 63L/16.6 gal...so the shape is going to be different and it appears that the 325i tanks don't have a crossover tube at the bottom.
                  That in and of itself is strange because if the later 325i's came with a single pump...how was the fuel from the left side pumped to the right side where the pump resides?
                  I started another thread here because I haven't seen any posts attempting this...or maybe I'm just really terrible at searching!
                  • e304me
                    • Feb 2006
                    • 1374
                    No way does the 318 tank hold over 14 gallons. I was running with the light on for like 75 miles and it only filled it with 12 gallons
                    • dude8383
                      • Jan 2005
                      • 10387
                      Well it definitely is 14.5gal because thats what is listed on realoem:
                      55L=14.5gal
                      I have filled up to 13 gallons before...definitely milking it there and something I wouldn't recommend since you're starving the pump.
                        The 55L 318 tank and the early 325 tank are the same, though the pump setup is different. The 63L 325 tank is different.The 55L liter tank uses a cross-over tube to equalize fuel levels, but the 63L tank uses a siphon in the left side to lift fuel into the right side of the tank.
                        • dude8383
                          • Jan 2005
                          • 10387
                          Interesting...does the late model tank require two pumps or does it have a similar setup like the 318is?
                          • Danny
                            • 14216
                            Late model 325 is 1 pump.
                            • dude8383
                              • Jan 2005
                              • 10387
                              318is - Does it look like this:
                              325i - Or...
                              LOL guess I just answered my own question...the 325i pump only has the feed line. I'm just confused by the difference in the two, why does the 318is one have a return pipe? Would the line just be shorter and attach on the left side of the 325i tank?
                              http://www.realoem.com/bmw/showparts...03&hg=16&fg=15
                              • dude8383
                                • Jan 2005
                                • 10387
                                Bumping this back up.
                                Tank has been replaced with a standard 14.5 gallon tank, decided not to fuck with the factory setup.
                                Yesterday buttoned everything up, on ignition pump turned on and started.
                                Car ran for approximately 10min and just died. Wouldn't start back up until I swapped back to old ECU and then had to swap in another fuel relay. Let it idle for about 10min again but it didn't shutdown.
                                This evening, inspected everything under the car, lowered it go to start the car and bam fucking thing does NOT want to start.
                                On ignition I heard the pump go on briefly and then cut out immediately.
                                Back track a bit, yesterday to check the symptoms I pulled the power to the fuel pump and the car gradually died. So this leads me to believe that it is not the actual source of the problem. Seems like some sort of electrical cut out almost as if EWS is enabled but it has a chip that cancels that out. I have been driving with that chip since October 09...
                                I'm kind of at a loss here :( I feel like I just replaced everything for no reason.
                                Still getting that check engine code and on ignition the voltmeter is showing 11v. Battery is nearly drained but I'm using a booster attached to the battery to try and start it up.
                                Any advice on another approach?
