FML Need help
  • blackhawkimpact
    • 2415
    FML Need help
    I was trying to tighten one of the screws on the thermostat housing and it broke inside. Now I used a screw extractor bit and it also broke inside the pilot hole I made for it, FML....Now I'm stuck and don't know what to do.
  • e30s50dan
    • Nov 2008
    • 2076
    If it's just one you may be alright. Use a good sealant and see what happens
    NASA
    BMWCCA member
    PCA member 25yrs
    1991 318IS slick top
    1997 M3 sedan
    2001 325CI DD
    “whoever turns the wheel the least, wins"
    • blackhawkimpact
      • 2415
      Yeah but with the luck I have, unfortunately, it's two, the ones at the bottom. One was already there when I bought the engine. FML? Yes, indeed.
      • SamE30e
        • Sep 2007
        • 4319
        Even with one itll leak, I forgot to tighten one and it pissed out.
        Drill it out and re-tap it.
        1985 325e 2.8 Turbo VEMS
        • blackhawkimpact
          • 2415
          Yeah, I'm going to have to do that
          • blackhawkimpact
            • 2415
            Yeah. Problem fix for now.
            I have another question. Why are my headers getting so hot at start up? Is it because the headers are open? I started it up today to because I was going to take it to a shop to connect the exhaust but my header got real hot at start-up and some smoke started to come out from the headers side
            • Adrian_Visser
              • Jun 2006
              • 2823
              Umm it's normal for the exhaust to get hot.
              How hot are we talkin here?
              If they are glowing at idle your shit is running super lean for some reason but I highly doubt that is happening since you have no O2 sensor hooked up and it will tned to run rich in that case..
              The burning smell is preservative oil or engine oil that go on the headers or engine oil on the hot side of the block burning.
              '89 Alpine S52 with goodies
              • blackhawkimpact
                • 2415
                Even after just 10-20 seconds on start-up? It's so hot that you can't touch it without burning your hand. The O2 sensor is plugged in.
                • gregslow318i
                  • Sep 2007
                  • 1918
                  thats normal.....
                  looking for a e30m50 swap harness adapter pm me $150 shipped
                  email nitroman12@gmail.com
                  • jrdeamicis
                    • Nov 2008
                    • 956
                    There are people who will come to your house. And there only deal is that they will extract studs, bolts, and broken stuff. You should call him. They are really good at it.
                    Past Car : E30 S50 6 Speed 5 Lug 3.73
                    Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
                    ___________________________________________
                    BNB Designs
                    Engine Swaps, Fabrication, Innovation, General Repair
                    Richmond CA
                    Julian 848-248-8029
                    • Farbin Kaiber
                      Lil' Puppet
                      • 29502
                      I used a few diamond tip dremel bits to whittle away at an eazyout in an exhaust stud.
                      • blackhawkimpact
                        • 2415
                        Yeah, I'm just going to take it to the shop for the broken bolts.
