hall effect cam sensor
  • R&D man
    • 79
    Can a hall effect cam sensor be used instead of a normal cam sensor?
    If not would I be able to use the plug from it and attach it to the regular sensor I am using a e34 harness 1995 and a 93 or 94 engine .
    Thanks
  • Adrian_Visser
    • Jun 2006
    • 2823
    You mean an OBDII cam sensor on an OBDI engine? Afaik no it won't work.
    '89 Alpine S52 with goodies
    • R&D man
      • 79
      hall effect
      Can I splice on a different plug so it will fit my harness?i
      • matt
        • 3732
        Don't do that. Get the right part... so it works.
        • R&D man
          • 79
          sensor
          I am not sure which part to buy because it is a 95 e 34 harness and the engine is 93 or 94 m50 with vanos.I have both the cam sensors , one from the e 34 and one that came with the engine.The problem is they have differnt plugs male and female.
          • matt
            • 3732
            They are the same:
            http://www.realoem.com/bmw/partxref.do?part=12141740959
            One of the cam sensors you have is not correct.
            • R&D man
              • 79
              sensor
              Thanks guys
              I will go home tonight and check the part numbers(my job gets in the way).Physically they look different one is plastic and one is metal
              • hoveringuy
                • Dec 2005
                • 2754
                Use which ever one fits. Functionally they are identical and just have different plugs. I'm using the OBD2 cam sensors from my M54 with OBD1 electronics. Only difference is the plug. They work fine.
