I bought a 93 325is at Copart (wrecked auto auction) and am parting it out, and actually am making an unreasonable amount of money because people are begging for stock e36 parts it seems. Anywho, while searching for a wrecked m3 for my next auction purchase, to use the engine out of, I came across a rear hit 74k mile 96 m3 that upon closer inspection has a supercharger bolted on, as well as a roll cage and five point harnesses on the inside. So I'll prolly pick this up for 2-3k and part it out, make my money back and keep the engine/supercharger for free.
Can I keep it OBD-II for the e30 swap or does it have to be converted to OBD-I? The reason I think it may be a hassle to convert is the supercharger setup, and even if it would be easy, that's an extra 30hp or whatever I don't need because traction will be an issue as is. And being 20 years old I don't want more then 280 whp or whatever it is in a 2700 lbs car, that just has trouble written all over it.
Does the DME plug into my existing computer connecter? Anyone know the wiring match ups for an 85 325e to a 96 s52? Should I keep the tans out of my current parted out 93 325i to use with 178k miles, or anything else? Anmyone have any sources for 5 series oil pans?
