Idle control valve
  • R&D man
    • 79
    Idle control valve
    I finnished my m50 swap and could not do the exhaust system so I sent it to a muffler shop.(400.00$ latter)I had to drive it home after they were done .....The engine had only run for five minutes since it was installed..I took a chance and drove it home....It ran terribly with no idle and popping in the exhaust.When I got home I found the ICV valve was off the manifold I hooked it back up and the car wants to rev to about 4000rpm ....when I unplug the ICV vave the same thing happens.....any thoughts on what to do?
    Thanks
  • sharky
    • Jan 2005
    • 2672
    Is your speed signal wire connected in the back of your cluster?
    • R&D man
      • 79
      speed signal
      yes it is
      • F34R
        sLaughter
        • 12376
        I know on the M20 there is a sensor under the throttle body intake. I remember having the same effects after I did a tune up. Just forgot to plug it back in.
        Instagram: @BWeissLeather
        Current cars:
        ~ '87 325 M30B35 swap
        ~ '87 535
        ~ 01 540 Msport 6spd
        ~ '06 X5 4.8is
