Car idling to low
  • markseven
    • Sep 2006
    • 5327
    Originally posted by 89325iturbo
    Still no progress couldn't find any vacuum leaks. What else could change after a little bit or coming up to temp. If the cel goes away when unplugging the o2 it seems like it would have to be based around that or air fuel ratio changing when it gets warmer??
    Seems like a given but some people, including me, forget: did you pull the fault codes?
    I Timothy 2:1-2
    • 89325iturbo
      • Mar 2004
      • 723
      I'm not able to. Stomp test doesn't work and my diagnostic port doesn't have power.
      • markseven
        • Sep 2006
        • 5327
        Can you get another TPS?
        I Timothy 2:1-2
        • 89325iturbo
          • Mar 2004
          • 723
          Sure I could buy one. But I tested it and it seemed to be good.
          • nrubenstein
            • 3148
            Why don't you power up your diagnostic port? It takes a few minutes to do it right in the adapter, or 60 seconds to do it quickly at the port.
            2002 BMW M3 Alpinweiß/Black
            1999 323i GTS2 Alpinweiß
            1995 M3 Dakargelb/Black
            - S50B32/S6S420G/3.91
            1990 325is Brilliantrot/Tan
            1989 M3 Alpinweiß/Black
            • 89325iturbo
              • Mar 2004
              • 723
              How do i do it at the port. I bought the adapter for the harness so i dont feel like tampering with it. What sucks is i sold my scan tool.
              • 89325iturbo
                • Mar 2004
                • 723
                Think it could be a fuel pump or filter? Maybe the pump heats up after running for a certain amount of time. Last time I ran the car got like 20 minutes it ran fine the whole time.
