Clutch swap ?
  • GGray
    • Dec 2008
    • 26
    Clutch swap ?
    I am doing a swap using the following.
    Getrag transmission
    E30M3 flywheel/clutch/pressure plate.
    e36 clutch fork with new TO bearing.
    The slave clylinder seems to not be contacting the clutch fork. I could not remeber if I needed to use an E30 Clutch fork in the swap so I used the E36 one ont he tranny.
    Any thoughts?
    Thanks.
    Gary Gray
    88 M3 M5x turbo track/race car
    89 M3 alpine/blk
    91 M tech vert
    91 GTi 16V
    01 325it aka: Wagonator...
    If you can take it apart you can make it faster....
  • Adrian_Visser
    • Jun 2006
    • 2823
    Use the clutch fork from the tranny you are using.
    '89 Alpine S52 with goodies
    • GGray
      • Dec 2008
      • 26
      I did the slave is not pushing the clutch fork against the pressure plate. Its like the slave shaft is too short..
      Gary Gray
      89 M3 alpine/blk
      91 M tech vert
      91 GTi 16V
      • Adrian_Visser
        • Jun 2006
        • 2823
        Are you using the euro 323i TO bearing?
        • e30s50dan
          • Nov 2008
          • 2076
          Which tranny you useing
          NASA
          BMWCCA member
          PCA member 25yrs
          1991 318IS slick top
          1997 M3 sedan
          2001 325CI DD
          “whoever turns the wheel the least, wins"
          • gobuffs
            • Dec 2004
            • 513
            I recently installed the throwout bearing off 90 degrees.
