Trying to get an s52 running in a 91 318ic. Engine ran in another e30. OBD-I harness was bought pre-wired from Zionsville. It's OBD-I, and has the EWS delete. We are getting spark and fuel (plug sparks while cranking when grounded, and fuel is dumping out of the return side of the rail).
While cranking, it's backfiring a lot, but nowhere near starting. After pulling the plugs, they looked wet.
CPS reads 540ohms.
I don't know how to test the cam sensor, can I measure resistance across the pins? I tried every combination, and couldn't get any reading of resistance. The meter didn't say 0 ohms, it basically said no connection at all... as if none of the pins are even connected through the sensor. I thought that was strange, but don't know how that sensor works.
We also tried a different FPR, and a good 413 ECU from a running m50 e30.
Another thing that was weird to me was the fuel pump fuse was only getting 10v while cranking. Shouldn't it be 12? Other fuses read 12v. I don't think that would effect anything though, as the return side of the rail was dumping fuel, which means the injectors should have had full pressure.
CPS reads 540ohms.
