swap exhaust options
  • cbusrehab
    • May 2008
    • 90
    I've been reading through the threads to figure out what options I have for exhaust. Its for an s50 and I already have the OBD1 manifolds. I've see some of the active autowerke track pipes for sale on various forums. Has anyone tried hooking up one of these to the stock OBDI manifold? I'm wondering if it would have clearance issues. I'll be using the AKG motor mounts and this will be mostly autocross/track day car so not worried about cats.
    Figured the cost of ebay header and custom exhaust work to connect to mid pipe might be close in price to used track pipe.
  • hoveringuy
    • Dec 2005
    • 2744
    Most of the e36 stuff will fit with a small amount of massaging. Depending on your resources (budget and tools) it may be easier to just to fabricate something from scratch.
    • cbusrehab
      • May 2008
      • 90
      I know the stock e36 header and midpipe will fit with some work such as spacers on the motor mounts or using THR control arm mounts. I was just wondering if anyone had used this combination on an e30, maybe track pipe has more clearance at CAB? I don't have access to a welder and suck at welding so if I go that route will be paying a shop to do it.
      • sushipower
        • Aug 2005
        • 156
        I went with e36 euro headers... fabricated new header flange, welded 2.5" pipes to E36 cat back.
        E36 cat back works with little modifications.
        • E30_80Y
          • 145
          i'm in the process of getting a custom exhaust too, been looking at the exhaust thread above this one, getting some idea's but keep the opinions coming!! thankz !!
          • jrdeamicis
            • Nov 2008
            • 956
            I used an entire E36 m3 Exhaust fit to my car. Its a big mofo. Cut off the down pipes and get the downpipes fitted to the car.
            Past Car : E30 S50 6 Speed 5 Lug 3.73
            Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
            ___________________________________________
            BNB Designs
            Engine Swaps, Fabrication, Innovation, General Repair
            Richmond CA
            Julian 848-248-8029
            • hoveringuy
              • Dec 2005
              • 2744
              See http://www.youtube.com/watch?v=Rn96Xp_vv5E
              Heavy. Sounds factory quiet.
