Starter delay
  • JGood
    • Jan 2004
    • 7959
    Starter delay
    Sometimes when I go to start my car (85 325e, m50tu) there is a delay from the time I turn the key until the time the starter does anything. I can literally hold the key forward for 3-4 seconds, nothing at all happens (no click, no ding, no nothing, then all the sudden the starter will engage and start the engine right up. If I leave the lights on with the car off for 10 minutes or so, it's really bad. Sometimes it won't start at all if I do that. But if I jump the car, it will fire right up, way faster then it would if the battery was dead. It almost seems like if the battery drops below a certain voltage, the car just won't try to crank over (say, 11.5 volts).
    I'm thinking maybe a faulty battery or starter relay?
    e30 restoration and V8 swap
    24 Hours of Lemons e30 build
  • Danny
    • 14216
    Battery is on its way out.
    • FredK
      • 14762
      In the interim, just borrow the battery from the combine until you can get to town and buy a new battery.
      • JGood
        • Jan 2004
        • 7959
        So I hook that up parallel or series with my current battery? Or should I just open them up and swap internals?
        • Adrian_Visser
          • Jun 2006
          • 2823
          Just take a bag of potatoes and stick nails with wires into them in series. A 25lb bag should do. Just make sure they are good Yukon Golds none of those crappy Russets.
          '89 Alpine S52 with goodies
          • FredK
            • 14762
            lolololol
            • avery0829
              • Dec 2008
              • 793
              This man knows his potatoes!
              • MattM
                • Apr 2009
                • 931
                __________________
                say what?
                Did this in some spare time in chem, i only got to 9 volts... i had visions of a car starting on it, but never got that far
                Full Build Thread Here
                • FredK
                  • 14762
                  Maybe use some lemons?
                  • kishg
                    • Sep 2006
                    • 2624
                    who needs a starter? cut holes on floor boards so you can jump start it flintstone style!
                    '12 F30 328i Sport Line
                    '91 SpecE30 #523
                    '00 Ford F-350 Dually Tow Vehicle
                    BMWCCA #360858 NASA #
                    128290
                    • erik325i
                      • Jan 2005
                      • 3567
                      You don't need to cut out your floor boards. Just install some Nawz and your floor will just fall out just as your manifold is starting to be in danger.
                      Erik
                      • Adrian_Visser
                        • Jun 2006
                        • 2823
                        Erik
                        Oh nowz!
                        • MattM
                          • Apr 2009
                          • 931
                          ahaha, what i saw going to say before i got distracted by the potato comment was that i battled a very similar problem for ages, it would be random too, car would start fine some days, and others i would spend 10 minutes turning the key until it would go. IT ended up being the battery not having the juice required. Took the battery for testing and it failed. Got a new one completely free under the 3 year warranty OEM batteries have! ;)
                          • 7pilot
                            • 475
                            Borrow a known good battery and install.
                            Put a voltmeter on the battery.
                            Check what the volts drop to when you crank.
                            if voltage drops to 9v starter has dead coils and is sucking the battery down.
                            If you test your current battery this way, then it could be the battery as well that may have a bad cell.
                            m
                            • JGood
                              • Jan 2004
                              • 7959
                              Well it got bad to the point where it won't start without being jumped. I put a new battery in it, no go. Still does the same thing. So that was a waste. I put the battery in my other car, it works fine.
                              Doesn't make any sense to me. Why would it only start when being jumped?
