Calling all muffler gurus
  • Dissembler
    • Jul 2008
    • 153
    I finally drove my m52 swap the other day but I have a problem. My choice of exhaust was fail. It was so damn loud that after 20 minutes my ears were buzzing. I knew it would be loud,, but I didnt realize it would be that loud (race pipe). the price was too good to pass up, and now im, payin for it
    My current setup is
    ebay headers-> 3" y pipe-> magnaflow cat->24" magnaflow resonator->16" shell length magnaflow muffler
    if a new bmw is 0 and a race car is a 10, i'd rate mine at 9.5. I'm looking to quiet it down to about a 5 (think about as loud as a ferrari?) and to do that I've been looking into the following mufflers
    Flowmaster 50 series delta flow (PN 843051)
    Dynomax VT (PN 17157)
    Dynomax super turbo (PN 17793)
    I like the super turbo the best right now because of its smooth flow design, but I fear it will not be much quieter than what I have now.
    Anyone have experience with these mufflers? Which one would you recommend. If you know of another muffler I could try, my only requirements are its got to be stainless steel, 3" center inlet, 3" outlet (any position) and sound volume of ~5
    Thanks!
    • 34844
    the super turbo is good, I have the same muffler
    there's also borla
    the flowmasters are more of a V8 thing. They'll still be somewhat loud, and can be quite droney, although with the cat and resonator it might not be so bad. I'd like to hear one that wasn't a straight through muffler actually.
    how large is that resonator? replacing it with a muffler might be a good idea, if changing the muffler alone doesn't help. a 3" center in/out Borla ProXs fits perfectly just in front of the subframe.
    • FredK
      • 14762
      Flowmaster 50 series delta flow (PN 843051): 4x9.5x17
      Dynomax VT (PN 17157): 4.5x9.5x16
      Dynomax super turbo (PN 17793): 5.5x11x16
      All of these mufflers are similar in size. I can nearly guarantee that the volume will not be radically changed by changing brands of mufflers. That VT does look intriguing, though.
      I run a 5x11x22 Magnaflow 3" muffler. It is not loud, but it drones a little (I do not run a resonator). Its about the largest muffler you can run in the space in the E30 rear wheelwell.
      I used to run the 2.25" version of that Super Turbo. It was stupid loud.
      • Dissembler
        • Jul 2008
        • 153
        the resonator is 24" long, 6" diameter (12649) My muffer is 12589. i looked at borla, but they are all flow through like my magnaflow. Would probably be way to loud unless they have super sound deadening inside of them.
        I know all the mufflers are similar in size, but with the exception of the super turbo, they are all multichambered which I hope will knock off a lot of db.
        :( about the super turbo, It looked so good cause of the interior design, but its still a smooth flow muffler so I believe you when you say it was stupid loud.
          • 34844
          my car is quiet with both of those mufflers (borla/dynomax)
          • Dissembler
            • Jul 2008
            • 153
            but you have a borla in the middle, its probably doing a helluva lot more than my magnaflow lol. I'd like to avoid cutting up the middle of the exhaust right now, the rear muffler is easy to chop off and weld a new one on.
            • e30s50dan
              • Nov 2008
              • 2076
              ebay ss > summit Y pipe > summit cat > borla muffler..not loud..nice idle sound,and little rasp......funny i had this on my m50NV,and it was raspy and buzzy sound,but its a world of a difference on my S50...I am happy with it
              NASA
              BMWCCA member
              PCA member 25yrs
              1991 318IS slick top
              1997 M3 sedan
              2001 325CI DD
              “whoever turns the wheel the least, wins"
              • Dissembler
                • Jul 2008
                • 153
                dan, no center muffler/res on yours?
                so nando and dan, does the borla really slash the sound levels that well, despite the straight through design?
                  • 34844
                  I don't know, it must be doing something. There wasn't much loudness change from the stock cat/supersprint to the single pipe, straight through exhaust. it's definitely a bit louder, but I'm not drawing unwanted attention from the exhaust by any means.
                  I'd try the rear muffler first and see if it helps, then change the center. a resonator will not make as much of a volume change as a muffler, though.
                  • 10Toes
                    Me Father Was A Tree
                    • Jan 2008
                    • 61222
                    My current setup is
                    Thanks!
                    Are you sure your exhaust is not leaking. I have just a megnaflow cat and muffler and mine is quiet at idle and only loud if I get on it, and even then it is not horribly loud. I do only have 2.5" piping and not the 3".
                    Is this exhaust used?
                    • Voluted
                      • 104
                      Graham, when I had the m42 in i had a stock cat, 20" resonator, and a dynomax superturbo through 2.5" dia piping and it was pretty loud. I'd also like to note that after about a year and a half (more importantly, after one winter) the superturbo started rattling as one of the baffles inside came loose from the welds. The issue was covered by their warranty but that meant cutting the old one off and getting another one welded on. When you don't have welding equipment it's not even worth replacing. The rattling always went away when the muffler warmed up but it was annoying with cold starts all winter long.
                      • e30s50dan
                        • Nov 2008
                        • 2076
                        same here..quiet/throaty at idle,but loud at r3v,but not that loud..i can still hear the intake K&N cone...sometimes i get a chubby :p:p
                        NASA
                        BMWCCA member
                        PCA member 25yrs
                        1997 M3 sedan
                        2001 325CI DD
                        • e30pq
                          • Apr 2006
                          • 579
                          I went with 95 E36 cat and a E36 M3 Remus catback. I used the cast S50 manifolds.
                          This is what my car sounds like.
