s50 rebuild?
  • spaceshuttle
    • 169
    s50 rebuild?
    thinking about getting an s50 it has 150000 on it. I did a little researching but couldnt find anything solid. Someone said that if the motor is good to just through it in and then Ive seen other people saw to just replace everything so kind of unsure what to do? I am going to look at it saturday it's still in the car and runs so iam going to bring a compression tester with me. Anything else I should maybe check?
  • Adrian_Visser
    • Jun 2006
    • 2823
    Warm compression, check the plugs for oil fouling. A rebuild is going to cost a few bucks.
    '89 Alpine S52 with goodies
    • 7pilot
      • 475
      Early S50 engines had valve spring seat problems.
      You may want to inspect the valve train.
      m
      • e30s50dan
        • Nov 2008
        • 2076
        m
        yes check to see build date..back of head..i bought an S50 with 140k on..i did a leakdown test and had to have the head rebuilt..i didnt doanything to the bottom end,replaced ALL gaskets,h20 pump,etc. did a leakdown after and all cyl are around 8-10%
        NASA
        BMWCCA member
        PCA member 25yrs
        1991 318IS slick top
        1997 M3 sedan
        2001 325CI DD
        “whoever turns the wheel the least, wins"
        • rneedham1979
          • Jul 2008
          • 852
          I have an S50 shortblock pretty cheap.
          Turbo E30
          Roadkill 80lb 93 octane OBDI tune
          BavSol Cylinder Head
          Stock S50 in. cam Schrick ex. cam
          Otis' tubular T4 manifold
          Oringed 87mm S52, Eagle rods and 8.5:1 CP pistons.
          GT4094r w/Batmowheel Impeller
          614whp@17.5psi, 100 Oct
          690whp@21psi, 100 Oct
          801whp@27psi, 110 URT
          Old: 1/4 mile: 10.91@144.38 (636whp)
          New: ?
          http://www.youtube.com/watch?v=L_f7fUVqblI
