Put the harness on the engine, see which sensor can most comfortable reach the mounting holes. The harness should be longer for the 1-3 sensor and shorter for the 4-6 sensor.
If not, bust out the etm, find one pin on the dme's connector (ex: bank 1-3 ground wire) and trace it back to the knock sensor with a meter
