Fan and radiator questions
    Currently I'm doing an M50 non vanos swap in an early model E30. I tried to shove the M20 eta fan on with a rad from an automatic (had it lying around) and I def get hitting.
    Is the problem that the auto rad is thicker or that the early model eta fan is too thick? Yes I can do a fan delete mod but I'm on an uber tight budget. I need something to get the car running asap.
    Fan delete is just a themostat, switch and water wetter, its like $70, just do it and stop screwing around with stuff trying to get it to fit. Just my 2 cents.
      Fan delete mod isn't really adequate cooling. Is this going to be turbo and used for drifting or is this a swap for someone else?
      '89 Alpine S52 with goodies
        It's gonna be NA but it will see track use.
          How much is it hitting by you think? Are you using the normal top raidiator support/ mount bracket? Sometimes by not using that bracket and zip tieing it to the body at the top can bring it away from the fan an 1/8-1/4 inch. Cause sometimes the bracket holds it out a little.
