s50 is in....now typical ps leaks!
  • JRKOUPE
    • Dec 2004
    • 3159
    so its a known e36 issue...ps leaks !..
    of course it couldnt be done w/ engine sitting out of car for 20 months...lol
    Any good fixes?.......get new oe hose w/ crappy crimp fittings?...
    or go standard proper generic hose w/ ol skool clamps?
    just wondering...I should know what to do....now but dont(yet):
    swapped engines ..do most set ups use the 24v ps res?..w/ e 30 hoses/cooler tubes? or e 36/
  • R&D man
    • 79
    leaks
    I have been chasing leaks as well
    I retightened the bolts on the pump housing.
    I also orderd new gaskets for the banjo fittings.
    I think the aluminum washers get to the point where they cant be crushed any further.
    I also had leaks at my chan tentioner which uses crush washers as well.
    • e30s50dan
      • Nov 2008
      • 2076
      dude....join the crowd!!
      NASA
      BMWCCA member
      PCA member 25yrs
      1991 318IS slick top
      1997 M3 sedan
      2001 325CI DD
      “whoever turns the wheel the least, wins"
      • herlsy
        • Sep 2009
        • 339
        Where is the leak coming from? I recently noticed a leak myself and traced it to the top of the rack where the coupler joins the steering column, some sort of rubber/seal cap where the splined part is.
        • JRKOUPE
          • Dec 2004
          • 3159
          Ill know more this wknd...Ill clean her up and watch it...but its hi up...Im guessing the clamps by the res....
          • e30s50dan
            • Nov 2008
            • 2076
            well if its a seal leak,DONT use Lucas PS stop leak,guaranteed to stop leaks.. MY ASS!!
            NASA
            BMWCCA member
            PCA member 25yrs
            1997 M3 sedan
            2001 325CI DD
            • herlsy
              • Sep 2009
              • 339
              NEVER use stop-leak anything
              • Charlie
                kid tested, administrator approved
                • 6686
                Carry an extra bottle of ATF in your trackbox and get used to a rainbow under the car.
                Welcome to swapped cars.
                -Charlie
                Swing wild, brake later, don't apologize.
                '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
                FYYFF
                • Wh33lhop
                  • 11705
                  Yes, don't. Shit's a bandaid at best and gunks up your entire system.
                  My PS has had a gnarly leak for awhile (right after I did the M50 swap, new reservoir etc), I just keep topping it off, I'll deal with it when I yank the motor to put something bigger in there. I keep distilled water, oil and ATF in the car anyway. :p
                  paint sucks
                  • kishg
                    • Sep 2006
                    • 2624
                    delete the PS. it's going to fail at some point, hopefully not when i'm behind you on a track :)
                    '12 F30 328i Sport Line
                    '91 SpecE30 #523
                    '00 Ford F-350 Dually Tow Vehicle
                    BMWCCA #360858 NASA #
                    128290
                    • MattM
                      • Apr 2009
                      • 931
                      mine has ZERO leaks! e36 rack too, original high pressure lines, new low pressure lines, new crush washers, and every line is DOUBLE hose clamped.i think this is important, before i did the double hose clamps i had a slow leak.
                      Full Build Thread Here
                      • Ara
                        • Jan 2006
                        • 365
                        +1
                        If I wanted PS id buy a Cadillac
                        • e30s50dan
                          • Nov 2008
                          • 2076
                          So BMW never had a non powersterring option? Not even on the 95 m3 lightweight? I race a 944 with non PS and it's perfect, but came only on 83' 944's. They are getting hard to find and expensive buddy just got one for his 944 turbo and paid $500 but worth every dime.
                          NASA
                          BMWCCA member
                          PCA member 25yrs
                          1997 M3 sedan
                          2001 325CI DD
                          • M-technik-3
                            • 18946
                            E30 came without ps in eu just not here in the states.
                            • FredK
                              • 14761
                              Yep. This is exactly what I did except my lines are single clamped at the reservoir. It will likely start leaking at some point because the hose clamps will lose some of their clamping force over time, but I'll cross that bridge when I get to it.
