WON'T START!? 91 e30 M3 S52 Swap
  • Lakis
    • Mar 2007
    • 160
    UGH:
    99 S52 Running OBD1 (91 E30 m3 chassis)
    The car did start and now only turns but won't start.
    Here is what we've tried:
    DME ECU with and without TMS chip on board. It started without the TMS chip.
    All Grounds checked.
    Scanner shows all sensors are operating; the cranshaft pos. sensor is working.
    We are NOT getting Spark or Injection Pulse.
    Getting fuel and there is (5 gallons in the tank).
    When I did get it started I didn't have the MAF hooked up; I don't know if that affects anything.
    help brainstorming?? Please.
    John K
    Park City, UT
    1991 BMW E30 M3 S52
    2003 Audi A4 Avant 1.8T
  • Bennetts22@aol.com
    • Jun 2006
    • 171
    what dme are you running? sounds like a ews problem
    • Lakis
      • Mar 2007
      • 160
      It is the Red label non EWS. 21.5 injector. and throttle body is 3 " to 3.5".
      thanks for responding
      John K
      Park City, UT
      1991 BMW E30 M3 S52
      • samiam3356
        • Jul 2009
        • 1901
        Red label 413? There are others that have a red label.
        Who did the wiring or did you buy an adapter?
        Originally posted by Roysneon
        $5 shipped?
        Originally posted by MarkD
        You are a strange dude, I'n not answering any more posts from you.
        • STAGGERED M3
          • Oct 2009
          • 368
          When you first started it. Did it stay on?
          • Lakis
            • Mar 2007
            • 160
            Sorry- I bought a used obd1 harness and I am using a TREEHOUSE adapter.
            John K
            Park City, UT
            1991 BMW E30 M3 S52
            • DREWHALL
              • Feb 2006
              • 1207
              Is it a 413 DME? Could still be EWS. Sounds like it with described conditions.
              • Lakis
                • Mar 2007
                • 160
                When I started it, yes it ran. But like I said now it won't start. If its an EWS issue; what does that mean?
                John K
                Park City, UT
                1991 BMW E30 M3 S52
                • gobuffs
                  • Dec 2004
                  • 513
                  If it ran with one chip and not the other, the chip is either wrong or installed backwards.
                  • Lakis
                    • Mar 2007
                    • 160
                    ERROR CODE: " ECU BATTERY VOLTAGE LOW "
                    I have a MAROON LABEL 0261 200 413
                    HELP
                    John K
                    Park City, UT
                    1991 BMW E30 M3 S52
                    • Lakis
                      • Mar 2007
                      • 160
                      We've made sure the notch was the same both times.
                      John K
                      Park City, UT
                      1991 BMW E30 M3 S52
                      • Lakis
                        • Mar 2007
                        • 160
                        Ok- so if it is EWS what are the fixes? Don't say new ecu please...
                        John K
                        Park City, UT
                        1991 BMW E30 M3 S52
                        • nrubenstein
                          • 3148
                          What is the part number on the TMS chip? Be aware that a chip for a silver label 413 will NOT work in a red label. Your issue is that you have the wrong chip.
                          2002 BMW M3 Alpinweiß/Black
                          1999 323i GTS2 Alpinweiß
                          1995 M3 Dakargelb/Black
                          - S50B32/S6S420G/3.91
                          1990 325is Brilliantrot/Tan
                          1989 M3 Alpinweiß/Black
                          • Lakis
                            • Mar 2007
                            • 160
                            Doug at Turner gave me the TMS chip for a NON EWS MAROON LABEL 413 ECU.
                            Plus- I am trying to start engine without the TMS chip installed now. The test computer is seeing the data on the TMS chip when it is installed (when I have it in the ecu).
                            I believe I have the correct chip= I will get you the part # though.
                            Any thoughts on the low battery message?
                            Thank you!!!
                            John K
                            Park City, UT
                            1991 BMW E30 M3 S52
                            • Lakis
                              • Mar 2007
                              • 160
                              I just put in another ECU and the car won't start still.
                              NOT the ecu.
                              NOT the after market chip (not installed anyway).
                              John K
                              Park City, UT
                              1991 BMW E30 M3 S52
