I present to you my luck: Coolant hose on the back of the head busted
  • Schwarz325
    • Aug 2009
    • 487
    Alright what would make this happen, other than a pressure build up? I went to bleed my cooling system today since i added coolant to it for the first time, and everything went smooth til i saw a river of coolant on my driveway. Upon a close inspection it was the hose in the back of the head. Like a dumbass i didn't replace it when the motor was out.
    So, i'll try to make it a one piece going from there to the pipe on the firewall, because i have them connected witha plastic union right now.
    Maybe it was clogged? head not circulating?
    Looks like the intake mani has to come off, or i can tilt the engine around, fuckkkkkkkkkkkkkkkkkkkkkkkkkkkkk :(
  • Dj Buttchug
    • Jun 2010
    • 7637
    jus fix it real fast. should be okay ya?
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • atldohc
      • Nov 2008
      • 359
      not really worth worrying about yet. old hoses can start leaking sometimes. :sad: i would replace it and thoroughly bleed the system. if you keep blowing hoses or see bubbles continuously coming out of the cooling system, then this can be signs of a blown headgasket. that is after all the air is bled out of course. hopefully its just a fubar hose though
      • Schwarz325
        • Aug 2009
        • 487
        That's what i'm hoping. If the water jackets are clogged up, it would pop a headgasket before itw ould a hose, amirite?
