AKG motor mount direction
  • bimmer630
    • 1230
    I wouldn't imagine one coming loose.. and you don't wanna crank on it too tight do you? She might twist.
    • 7pilot
      • 475
      M10 grade 8.....34 ft /lb.
      M10 Grade 10.9....48/ ft lb
      M10 grade 12.9...59 ft/lb
      Derived from E36 ETK.
      When I use after-market parts in critical areas, I do a monthly check.
      m
      • mtlbloodshot
        • Jul 2011
        • 761
        Just spoke to someone from AKG and said that the MM5030 Mounts should be torqued at 20 ft-lbs
        MY BUILD THREAD
        http://www.r3vlimited.com/board/showthread.php?t=235231
        INSTAGRAM : @luchcolaneri
        • bimmer630
          • 1230
          how did everyone "clock" their mounts? it seems like I can set the engine forward or backward with the offset mount..
