Id describe the smoke I saw as what youd see as blowby if you opened the oil fill cap on a hot motor
power steering res leaking
it has cured itself. I have no clue how but its not leaking anymore and the witches brew has settled down. all I have left is one check engine light code to figure out.
Im thinking it wasnt bled well enough and the pump was cavitatingComment
Had the same problem during my last autocross...then it stopped so maybe it needed to be bled as well...Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
There is also a restrictor in the E36 PS line that youre prob missing...
Check Us out on Facebook
Full Product Line Tuning
OBD2 Tuning Available! OBD2 E36, S54 Swap, S62 Swap, etc: tuning@MarkertMotorWorks.com Dyno ThreadComment
Some people argue it doesnt do anything but yeah, it is there on the E36:
Stolen Picture: http://media.photobucket.com/image/E...e/IMG_2340.jpg
Thanks im going to search the etk.Comment
There's a line very much like that in the E30 M3, takes out the overboosted feel.Comment
Well the one in the E36 is in the return line to the res...
Probably to slow the volume of fluid but it increases the pressure.Comment
True.
