What would have to be changed to swap an s50 into my m50 car? I assume mounts are the same, would much have to be changed aside from wiring? I searched around and couldnt find much.
Its nv, so i'd just need to buy a motor with a dme and wiring harness and itll swap right in with my mounts?
You'll want to double check your c101/x20 connection, not sure if the pinouts are the same. If you have an adapter made, you can possibly re-use it. If you hardwired the engine into the car, you'll need to cut the old one out and start from scratch splicing the new one in.
Mechanically, everything is identical, the engine is identical on the exterior (except for the hump in the valve cover for the vanos, which is irrelevant).
