M50 wiring harness/slight list question
  • i3uller
    • 249
    Ok, I am going to be buying this setup for my M50 swap:
    1994 M50tu b25 w/ 70k miles and formerly mated to an AT
    e36 5 speed tranny with 1:1 fifth gear
    e34 oil pan, new pickup, oil pan gasket, dip stick, and tube already installed
    Zionsville Lightweight Flywheel Kit
    New E28 motor mounts
    Modded E21 brake booster
    E30 driveshaft
    Wiring harness included...
    All this for about 1700 bucks. I know I need an ecu and a maf and a new 88+ coolant reservoir. Is this a good deal?
    Also if someone could list what else I would need to fit this into a 1987 325is that would be amazingly helpful. And one last request. For the people that have done it...how exactly do I go about fitting the wiring harness from the M50 to match my E30? Every suggestion will be helpful. Thanks in advance!
  • DEV0 E30
    • Oct 2004
    • 8897
    Treehouse Racing Adapter
    Supposivly it's worth it. I wouldn't know, I'm still a ways off from planning my m50 swap. Best of luck, document it if you can. :)
    • i3uller
      • 249
      ya im gonna try and take photos etc.
      400 dollars!!!
      Yea right!
      • Teaguer
        • Sep 2004
        • 6167
        Dude , read the friggin thousand page thread on the swap !
        That is all .
        • i3uller
          • 249
          That is all .
          I would....but it is a thousand pages long and I need to know exactly what my 87 needs for it once i have the parts that I have.
          • Teaguer
            • Sep 2004
            • 6167
            Do yourself and us a favor and read the entire thread .
            What you need is covered several times and you will also learn plenty .
            • clutterbucker
              • Jun 2004
              • 481
              the thread is confusing and of course poorly organized since it's a thread and many people talk while few have real knowledge to add...not to critisize of course because I love the thread.
              Anyway, I'm buying the treehouse wiring adapter because I'm having a shop do it, and it seems like a worthwhile time saver.
              I will say that (you have a 3.64 diff right?) the 1:1 fifth is probably going to be annoying. I would reccommend going to a lower gearset sometime. Make sure you have the E36 stock metal mounting arms alongside the E28 rubber mounts. I seems to remember that only the 88+ radiator will work, not the 87. CHeck that out on the 40 page thread. Otherwise, I see nothing wrong....enjoy!
              - 2000 Audi S4 Stg 2 (sold)
              - house (bought)
              - 1997 Civic Hatch (shaky but driveable)
              - 2010 Sportster 1200 Forty Eight Ed. (vroom)
              - 1991 318is S50B30 (TBA)
              • Herb
                • 430
                Buller,
                there is someone on ultbimmer forum with an ecu for $250, I found one for 200 shipped, so i turned it down. READ THE THREAD. print it and highlight the the things you need, that's what i did. problem now is finding the performance parts for the "non" performance cars... e28 535i urethane motor mounts - can't find them anywhere (may not exist thought and don't know what cars us the same mounts).
                hope this helped alittle,
                Herb
                bmpr stkr: real racers go left and right... so tru
                • Brew
                  • 3060
                  Do you have a lot of engine movement? My 535 mounts are very solid- the entire car rocks when I rev the engine.
                  i3uller:
                  Most people will recommend a 3.25 diff with the e36 tranny.
                  I'm not sure if the Treehouse adapter is worth it. There really aren't very many wires to splice, and its pretty hard to screw up if you go by www.akgmotorsport.com and the DOHC thread on this forum.
                  And like clutterbucker says, you will need the 88+ radiator and e36 325i coolant hoses. Its probably not a bad idea to replace all of the hoses while the motor is out of the car.
                  I'm sure there are a few more little things that you need, but I'm sure that they are all in the thread.
                  '91 318is
                  • Herb
                    • 430
                    Right now the motor has TONS of movement... its on a pallet in route to Nashville... **lol**. But that's been the best answer to my mount qustion yet. :D Thanks.
                    Herb
                    • Addissimo
                      • Mar 2004
                      • 1820
                      I have a 413 red lable ecu that i'll sell for $200. I would definately do the wiring harness myself. I cant imagine spending $400 on that! It took me an hour, and that was using the e34 wiring harness which i had to figure a few things out with.
                      -Addis
                      Doing something M50 related? -> http://www.addissimo.com
                      On Myspace? ->http://groups.myspace.com/r3vlimited
                      BF2142 SN = BillyGoose
