3 Main Relays on engine harness?
  • Chrisv006
    • 375
    Im missing all three...m50 vanos motor
    Fuel pump, DME, and o2 heater? I cant find decent part numbers or anything for them. These are the last parts I need to try and start this thing..:???::???::???:
    Can anyone point me in the right direction?
  • e46s54dr
    • May 2008
    • 1059
    I believe that they are the exact same relays as the ones under your hood in your fuse box. Any autoparts store will carry them. They are quite common.
      • 34844
      the main relay is not the same as any in the fuse box, it's a double 87 output relay.
      you can get them from pelican parts. the main relay should be white.
      • two240s
        • Apr 2009
        • 395
        any salvage yards around you? that'd be the easiest and cheapest
        • StereoInstaller1
          GAS
          • 22679
          Discontinue this thinking immediately.
          BMW uses only 1 "normal" pin configuration...and it is not common.
          Closing SOON!
          Thanks for 10 years of fun!
          • Chrisv006
            • 375
            I know there there not standard...the white main relay is easy, the other two are both 4-pin and I think there both the orange relays on bavauto.
            • e46s54dr
              • May 2008
              • 1059
              Sorry for the misinformation, I kind of alway thought that the orange relays were all the same. Never really looked at them I guess. T:-?
