Do the U-joints on the driveshaft really have to be lined up with each other?
  • u3b3rg33k
    • Jan 2010
    • 2452
    I left my OE tailshaft bolted to the diff when I did my 5 speed swap over 30k miles ago.
    Got the wrong model year CSB, so I widened it to make the holes line up (stick welder + water sprayer to keep the rubber happy).
    I'll let you know when I start to see problems.
    Ich gehöre nicht zur Baader-Meinhof Gruppe
    Originally posted by Top Gear
    Just imagine waking up and remembering you're Mexican.
    Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
    • Schwarz325
      • Aug 2009
      • 487
      I finally found the marks and aligned them. Now the car vibrates when it's idling, but it slowly goes away and comes back lol..it's pissin me off
        • 34844
        well vibrations at idle can't be the driveshaft, because it isn't moving when you are stopped.
        • Schwarz325
          • Aug 2009
          • 487
          I think i put too big of a spacer underneath the driverside motor mount, so i'm gonna try a smaller one
          • Schwarz325
            • Aug 2009
            • 487
            well i drove it some more and it seems like the vibrations are still there when driving, especially when i first take off, it's resonance/vibration all over the cabin.
            couple questions?
            can you overtighten the bolt that holds the 2 piece of the driveshaft together?
            and i also never preloaded the csb? would that have anything to do with it?
            The csb didn't just slide on the d/s, i had to basically tap it on there, and it took a bit of force, is this normal?
            • 328ijunkie
              • May 2007
              • 3961
              The CSB is pressed on and ive never noticed the difference between preloading and not, ive done it here or there on my own cars and never noticed a difference. As far as aligning the DS goes, there should be factory paint marks, if theyre not there for whatever reason the Bentley describes what JGood Mentioned as a plan B...
              Check Us out on Facebook
              Full Product Line Tuning
