starter gear spins but does not engage flywheel - e30 m50nv 260
  • boyd_dave
    • 42
    so im wrapping up my m50 swap and testing the wiring. when i turn the key to crank the motor, the starter sounds like its spinning really fast but does not engage the flywheel at all.
    I am using a 92 m50nv motor mated to the getrag 260 using the m20 starter. I had the flywheel lightened and resurfaced to clear the oilpan. I know it clears fine and the motor turns over by hand.
    Did I wire my starter wrong? the m20 starter has 4 posts (from 88 325is) one I know is ground and one is battery that gets the firewall connection and the alternator connection. The e36 wiring harness had 2 smaller starter connections that I connected just like the e30. the small connector from the e36 i put on the small terminal and the larger one on the larger terminal...
    anyone have any ideas?
    THANKS!
    Dave
  • 99em1
    • Dec 2009
    • 200
    Do you hear any click before it spins?
    • boyd_dave
      • 42
      no. just instantly spins. thanks for helping.
      im realizing that the solenoid is not engaging/powering up to move the starter gear forward. but im not sure what ive done wrong with the wiring... should i double up the small wires onto the same post? or swap the wires? I would then have to change the round electrical connection...seems counterintuitive, but i dont know.
      what do you think?
      dave
      • e46s54dr
        • May 2008
        • 1059
        If the two wires on the starter are reversed, the started will spin and not engage like what you're expiriencing. It happen to me awhile back after I rebuilt my m20 starter. I know yours is a 24v but it's setup pretty much the same. If not then your solenoid is the culprit. Btw, is the grounding cable form the started to the solenoid still connected?
        • sharky
          • Jan 2005
          • 2672
          solinaoid could be stuck, give it a whack with a BFH, if not find a good used starter
            • 34834
            double check the starter wiring.
            I think the M50 starter is similar:
            Upper left (smaller post) should be pin 15 of the C101. Lower right (larger post) should be pin 18 of the C101.
            • boyd_dave
              • 42
              here's a link to a video that is exactly how my car sounds:
              I definitely have the m20 starter installed with a shaved m20 flywheel. I just checked and it is wired correctly.
              I haven't hit it with a hammer yet to see if its stuck...
              • sharky
                • Jan 2005
                • 2672
                solinoid isnt engaging/ starter gear toast. Swap in another unit but hit it w/ BFH just incase
                • boyd_dave
                  • 42
                  thanks to everyone who helped me out with this. a big F hammer did not work. removed starter (what a bitch to remove...a lot of extensions and ujoint adpaters...) and the bendix was not only seized but gear was seriously hard to turn.
                  got a rebuilt from shmucks/orielly and its good to go!
                  Dave
