Car cuts and turns off during harder(er) acceleration
  • graphikg
    • Jan 2008
    • 1614
    If I drive softly, my revs will climb up fine. I only went to 3500 though because of my new clutch and flywheel. However, if I try to accelerate harder my car cuts and turns off at 2500. I drove softly until 3000 and noticed it didnt cut, so I tried to accelerate harder again and it cut and turned off at 3500rpm. I also seem to feel like a loss in power.
    What could it be? Fuel pump relay? fuel filter? fuel pump?
  • dreamchasin
    • 3892
    Unhook your battery or ECU, whichever is easiest for you. Plug it back in. Start it up and immediately get on it. A buddy had this issue in his m50, it was his ECU.
    EDIT: this MIGHT be your problem, but hope it helps.
    90 325is alpine2 m50b25 becoming a dorifto car.
    • graphikg
      • Jan 2008
      • 1614
      Wow I will try it. How long should I have the batt unhooked for?
      • mattdk318i
        • Jun 2006
        • 3953
        what engine? im assuming its a 88 M20?
        • ZM Blue Devil
          • Dec 2006
          • 13836
          check your ignition wires.
          Levent
          %20levent@gutenparts.com
          Ladies:
          • graphikg
            • Jan 2008
            • 1614
            Its an 88 body with an s50 swap.
            You mean the coil packs?
            • Adrian_Visser
              • Jun 2006
              • 2823
              You aren't still driving around open header are you?
              '89 Alpine S52 with goodies
              • graphikg
                • Jan 2008
                • 1614
                I am trying to... but it still cuts when I try to accelerate. This problem was there even when my exhaust was connected with the old M50 headers before I changed them to s52 headers.
                • graphikg
                  • Jan 2008
                  • 1614
                  I am just wondering... The ecu I have on the car has endured an over-rev. Could it be that it is protecting itself and shuts off even if I just try to accelerate a little harder?
                  • e46s54dr
                    • May 2008
                    • 1059
                    I had a very similiar problem with my m20 and it ended up being one of the ground wires from my started post was loose. I rechecked the wiring and tighten them down and the problem never came back. It may or not be the case for you but it might help.
                    • dreamchasin
                      • 3892
                      Shouldn't need to leave it unhooked for long at all.
                      This is the 24v swap section...
                      • 328ijunkie
                        • May 2007
                        • 3961
                        Engine Ground im betting
                        Check Us out on Facebook
                        Full Product Line Tuning
                        • graphikg
                          • Jan 2008
                          • 1614
                          Thanks guys, I appreciate it. Please keep the ideas coming. I am going to try to eliminate some of these possibilities. But also to mention, I do feel a loss in power as far as the motor goes. The motor seems to be less ballsy; and I can get up to about 3000rpm if I go very smoothly through gears. But if I even try to put a little bit of throttle on it, it can shut off even at 2500 or 3000; the shutting off is like the key was just taken out of the ignition while driving. WEIRD!
                          • Fusion
                            • Nov 2009
                            • 3659
                            I would guess MAF sensor personally.
                            Tried cleaning the throttle body?
                            • e30rapidic
                              • 2167
                              ever resolve this?
                              '87 325ic, powered by S50.
