WTB e34 oil pickup
  • wobbie
    • 396
    WTB e34 oil pickup
    Im swapping an m50 and i have the e34 oil pan but i didnt get the oil pickup. Does anyone know where i can get one. Thanks
  • sharky
    • Jan 2005
    • 2672
    pelican parts or Blunt on here, about $30, make sure you get the gasket too
    • wobbie
      • 396
      this is the only one i found and its 439 bucks? wtf!!!
      http://www.pelicanparts.com/cgi-bin/...2D%39%35%29%20
      • wobbie
        • 396
        nevermind i think i found the right one.
        will This bolt right up to where the old one was?
        http://www.pelicanparts.com/cgi-bin/...35%29%20%20%20
        • FredK
          • 14762
          Yes, exactly.
          Get the gasket that goes with it as well.
          • spaceshuttle
            • 169
            yes it bolts right in. You have to do something about the bracket for the old one though.
            • wobbie
              • 396
              any isuggestion for what to do witht the bracket?
              • FredK
                • 14762
                Most people just break it off by wiggling it back and forth until the metal fatigues. If you remove the bolts that hold it on, it's generally accepted that you ought to get two new bolts.
                They also get tightened to a torque angle, not a torque value.
                So, if you have the tools to put it back to the proper torque angle and 2 new bolts, great! If not, just break it off.
                • wobbie
                  • 396
                  ok thanks
