waht do i need from an m20
  • SwiftE30
    • Jun 2010
    • 998
    I'll be pulling my m20 out of my 89 325i. I have a full 97 m3 that i will be sourcing the engine and transmission from. I'd like to know what parts from the e30 m20 engine/engine bay i want to keep. I dont want to sell the engine and realize i needed a part from it for the swap. any info helps. thanks
    1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IP
    • 34844
    other than maybe a relay or two I don't think there's anything from the M20 that you can really use.
    • FredK
      • 14762
      I would snag the M20 starter cable.
      • blackhawkimpact
        • 2415
        Starter?
        • Adrian_Visser
          • Jun 2006
          • 2823
          If you're sourcing the tranny and flywheel from the e36 you need the e36 starter etc.
          Keep the m20 radiator, as mentioned the cable from the junction block to the starter as well as the cable from the junction block to fusebox.
          '89 Alpine S52 with goodies
          • blackhawkimpact
            • 2415
            Oh. Didn't see he was also getting the tranny from the e36. My bad doggy.
            • SwiftE30
              • Jun 2010
              • 998
              great. got both of them thanks.
              • monkeytaco
                • Jan 2010
                • 882
                Also keep the coolant hose that goes from the back of the m20 head to the heater core inlet, it works perfectly for the s52.
                Looking for a clean e30 shell for a project.
                • 10Toes
                  Me Father Was A Tree
                  • Jan 2008
                  • 61222
                  Coolant temp sensor.
                  • 328ijunkie
                    • May 2007
                    • 3961
                    and more... search.
                    Check Us out on Facebook
                    Full Product Line Tuning
                    • SwiftE30
                      • Jun 2010
                      • 998
                      anything else?
                      • SwiftE30
                        • Jun 2010
                        • 998
                        This might be a retarted question, but what are these used for? I still havent quite got to the rebuilding stages of my engine so i havent really figured everything out yet. thanks for the help
