help reading the etm
  • 325islovE
    • Feb 2007
    • 133
    One question to clear this up for me, when i read about the plug for the dme(x6000) there is a pin chart and it says E=input A=output M=ground. Does this mean that i should be getting power in the pins that are designated A. output.
    Or is it the other way around i should be getting power in the pins designated E input, as in its an input signal to the dme.
    skip to page 125 of 436
    1988 325is alpine
    1989 325is zinno RIP
    1992 325ic alpine
    1986 325e cirrusblau
    • 34839
    not neccesarily. Some outputs are activated by switching to a ground. Others are activating by supplying a voltage. Inputs can work the same way, some are ground level signals and some are voltage. But grounds will always be grounds.
    • 325islovE
      • Feb 2007
      • 133
      so looking at the etm and checking for voltage at the ecu plug is kind of a wast of time or probably more complicated then what i had in mind. What your saying makes sense because i was getting voltage in some pins and other pins that seemed like they should have had voltage werent.
      1988 325is alpine
      1992 325ic alpine
        • 34839
        not if you know what you're looking for. :)
